- Jacksonville, Florida
I have a question...
are you guys using 9mm or 26mm in these areas?
Area#1:
Inside wall of the foot hold...
i tried 26mm but it was really tight and tough to fit...it kinda pushed the inside of my foot under the outside part of the wing
I then used 9mm plush and that was much better...i tried to find some pics of others but couldnt really tell from the photos
Are you guys running any padding on the inside wall of the foothold or just 26mm top and bottom?
Area#2:
Not really a critical area but this photo is just in front of the foothold wing and being the front foot hold.
I laid down 9mm but I thought maybe I should have used 26mm instead...
What are you guys putting in this area(just the walls only)?
Area#1:
Area#2:
