New 'Water Out' Shop -Bilge Pump, Scupper, Versiplugs, Hood seals, Billet outlets, hose, mounts, etc.
JetManiac
Stoked
orlando
Bilge Pumps, Versiplugs, Scuppers, Hood Seals
Keep the Water out of your ski!
Bilge Pump kit 129.89
Rule Bilge Pump 360gph
Rotary 3 position waterproof bilge switch
Billet bilge outlet
(black or silver in straight or 45 degree)
Bilge outlet hose 2ft.
Billet single bilge pump mounting bracket
(for Blaster 1 or 2 and Superjet '94-up)
Hose clamps
Bar mount Bilge Pump kit 179.90
Handlebar mount bilge switch
-Mounts to handlebars or mounts to underside of most aftermarket throttle levers.
Billet bilge outlet
Hose clamps
Yamaha Start/Stop switch mount Bilge pump kit 189.89
Rule Bilge Pump 360gph new 32.90
(less cavitation with the slower RPMs in this pump)
Rule Bilge Pump 500gph new 34.90
Black bilge outlet hose $2.49/ft.
Black or white lightweight marine bilge hose specially designed to be used with bilge pumps. Hose has smooth mounting cuffs every 12-inches and is corrugated to be flexible for easy installation and is resistant to acid, detergents, oil, gasoline, diesel, fuel, and salt water.
Hose clamps for bilge hose -marine grade stainless thin lightweight $2.49
Replacement Rule blue bilge mounting base 10.95
(for older style pump)
Replacement Rule black bilge mounting base 18.95
(Gas and impact resistant)
ADA Billet bilge outlet -straight $15.95
(black, silver, blue, red or orange)
ADA Billet bilge outlet -45 degree $18.95
Thrust low rider bilge outlet 20.99
Blowsion Billet single bilge pump mounting bracket 29.95
PJS adjustable single bilge pump bracket 34.90
PJS adjustable Dual bilge pump bracket 45.90
Blowsion Billet dual bilge pump mounting bracket 47.10
Bilge pump switches
Rotary 3 position waterproof bilge switch 39.95
Watt hole recessed mount for rotary switch 35.
OCD Solutions "Surf Armor" Toggle Bilge Switch 55.90
index.php
Handlebar mount bilge switch 104.80
Yami Start/stop switch mount bilge switch 99.85
*mounts to bottom of Yamaha start/stop switch
Bilge switch Kawi start/stop switch mount 97.95
*mounts to bottom of Kawi 440/550/750SX/750SXI/800SXR/1500SXR start/stop switch
Replacement handle bar mount bilge switch 78.90
(with 9ft wire harness) fits Blowsion s/s mount and universal bar mount holders
Waterproof In-Line HD fuse holder 9.90
Tidy Bilge Harnesses
Tidy Bilge Harness for Yamaha Standup Watercraft; Fits Blaster, Superjet and FX1
Designed to install directly into any Yamaha electrical box, it makes for a clean and simple bilge pump installation.
- Fully Assembled E-Box harness: grommet, marine grade #16 tinned wire, protective wire loom covering, heatshrink, OEM Style connectors for a plug and play install into your e-box.
- Extra loom, heatshrink and connectors to connect your current switch and bilge pumps to the harness.
- OEM style waterproof inline fuse
- Adapter harness to connect your switch to the harness.
OCD tidy bilge single bilge harness $49.89
OCD tidy bilge dual bilge harness $59.89
Yamaha OEM siphon bilge parts
Siphon bilge plastic pickup -New OEM Yamaha $34.99
Siphon bilge pickup -Used OEM Yamaha 17. (limited availability)
Siphon bilge stainless bracket -Used OEM Yamaha 14.95
Siphon bilge 90 degree fitting -New OEM Yamaha 13.99
(not a std 90 fitting, has a vacuum breaker in it for siphon use.)
Versiplugs / Hull Drains
Versiplug -Yamaha $34.90
*These replace your OEM Yamaha drain plug with versiplug self draining setup.
Just unscrew stock drainplug and screw these babies in. You can carry oem plugs as backups or for extended in-water storage use Versiplug 'night caps.'
* fits B1, Venture, Raider, 4stroke SJ, and many other Yamis.
Versiplug 'night caps'
*locks the versiplug drain closed for in-water storage
Yamaha OEM Blaster drain plug assembly -New 37.99
*hull side drain fitting with gasket and drain plug with Oring
Yamaha OEM Blaster drain plug assembly -Used 19.50
*hull side drain fitting with gasket and drain plug with new Oring
Hull drains -new with removable O-ringed drain plug $7.95/ea.
(includes stainless steel mounting hardware)
Versiplug -for above listed hull drain 34.90
Versiplug - Kawasaki 34.90
These replace oem kawasaki drain plug with versiplug self draining setup.
You can carry oem plugs as backups or for extended in-water storage.
Versiplug-R 49.90
*larger size Versiplug which can mounted anywhere on the back of your ski.
Versiplug for Krash hulls 75.90
*Designed to replace rear facing flap scupper on most Krash hulls
Versiplug micro 2.0 mini hull drain $35. sale 29.95
*new design- stainless threaded hull insert, new micro threads into hull insert for easy removal for cleaning debris or for plugging for storage in water
Versiplug micro 1.0 mini hull drain $32. sale 21.95
*self cutting threads screw into a 3/8" hole
Versiplug-MAX Hi Flow 85.95
*Largest Versiplug which fits in a scupper tube. Designed to replace leaking flap style scuppers. For 2" PVC tubing.
Versiplug-Rickter 122.
*Designed to replace RRP rickter hull scupper (tube size 2.75")
Thrust EZ drain Rickter 130.
Thrust EZ drain 2” 130.
Duckbills -replacement 19.95
Scuppers
XScream Scupper assembly $90.
-Drain your ski FAST with XScream Billet Aluminum high-flow scupper flanges. Easy to install using light gauge PVC tubing.
XScream scupper replacement flap 21.95
TigerCraft scupper replacement flap 20.95
LSP scupper replacement flap 21.95 (pre 2025 Revolver)
LSP scupper replacement flap 21.95 (2025-up S1, Revolver)
RRP Scupper aaembly $79.95
RRP scupper replacement flap 20.95
Hood Seals
Watcon replacement hood seal 39.95
(Fits all SJ, Blaster, B2, FX1, Octane, SXR, and many other skis)
Yamaha OEM RN SuperJet Hood Seal $215.99 sale 168.80
(fits all RN Superjets 1996-2020)
RRP Rickter hood seal 54.95
Secondary hood seal for Rickter hulls 37.95
LSP Revolver / EME Roid hood seal 39.90
Kawasaki JS 300/440/550 a/m Hood seal 26.89
