would 3 layers be sufficient for running straps and useing the blowsion style mounting for the straps? This is a dilemma im in right now as Im about to refoam and reglass my SN tray. I see how thick the stock tray was that I had straps in, and Im not sure if 3 layers of 12oz would be as strong or as thick? maybe just do the washer with acorn nut deal?
I haven't done my tray yet so I can't help you with how to secure your straps. I have been looking for a reasonable way to put in hull inserts. I was looking into Stainless Tee nuts that you can get at Ace. They are only a buck or 2 each, made of stainless. I am not sure what stainless but I am going to assume it is 304 stainless.
The Tees come in a flush finish and with raised spikes. I was going to give the raised spikes one a try for holding in my waterbox and fuel tank when I get to that. Unfortuneatly, I haven't go there yet so I can't tell you for sure it it will work. It would also require you to be able to work on the tray from the inside, so that would work if you cut out your tray and then glassed it back in, but if you plan to just lay glass over the foam, you wont be able to use the Tee screws i plan to use on my stuff.
It's not a question if 3 layers of glass will be enough. The question is how many layers of what weight. I just built my X2 hood out of 3 layers - 1 1708 biax, 1 24oz weave, 1 1708 biax. It's built like a brick
house because it has to support my weight.
3 layers is good. The question is of what cloth. If you are going to be riding the lake with padding, 3 layers of 1208 would probably be just fine. However, the tray is flat, no curve to give it strength, so 3 of 1208 may not be enough for hard abuse. 3 layers of 1708, or the sandwich 1708/24/1708 I did my hood out of may be better if you are taking some huge landings in the surf.
Ultimately, it is hard to determine how strong it is going to be when it is done. I haven't seen any magic equasions to determine how much of how many layers you should use. I have limited experience. I just tell Pat at fiberglass coatings in St. Pete what I am doing and he tells me how much of what kind of glass I should use for the job. Everything I have stated is based off what he has taught me in my limited projects. I haven't broken anything yet, but my stuff may be heavier than necessary.
