Freakrider
X247
- Tampa Bay area
What ideas have you guys come up with ?
I took a flat piece of stainless about 1.5" wide and 3" long.Drilled two holes,one large enough to hold a tow loop and the other that fit the pump bolt. Attached it to one of the rear bolts on the pump.lt did ok but the last time l towed somebody it must have worked the bolt and pump loose.So l did not do a great job of getting the bolt tight or had another problem.l don't use locktite,so maybe that was the reason.l still think that is the way to have a tow loop,just need to refine it!
Why not use a regular bow eye and a tow loop from Idok?
It has to be off center because the nozzle is right at the top and usually a bow eye is centered.
This is how i have been doing my skis for a few years. works perfect
I used a 1" nylon strap folded once over then bolted through the folds with a washer, then through the edge of the tray,offset just outside of the pump area. used a 5/16 button head allen hidden under the turf. I couldnt be happier with it, also serves as a handle to drag or spin ski around on beach etc. I have towed with it and use it to winch my ski in and out of the back of my pickup rack setup every time with it and never had any issue.
Nothing great, but we use the pump ear alot for tying it down.
All great ideas! The one thing we all overlook is how much solid area is there on the rear end of a Freak from the outer edge towards the inside..l bonded my freak and remember there is not much area in the bond line on the stern edge.
l like what you did RMBC! l would want to put some washers and nuts on the top of the tray.So that means me returfing.......
Maybe Tem could give us some input
