- marion ohio
Has any body ran the 155 pump out of the raider. If so please give info. I posted this in the driveline section but got no response.
Ive allso just bought a complete 1200 driveline/pump assy to try and fit!![]()
I figured since it was coming out of a raider it would probably have the same bolt pattern and spacing as the 144 pump
Awesome to hear that your looking at one of our motors! I just bought a 155 pump out of a 97 wave venture and will be using that in my newest Bob buildas soon as I get my hull and get it setup I will be posting the full build thread. You can call the shop and I can give you more info after we have done it. The 898 rips the 155 pump that Zack has in his Circus
The 155mm oem pumps are longer. You will need to do some modding to boltup in hull not designed for it.
Remember the big performance comes from 155mm skat mag pumps (like zach is running), not oem 6 vane 155mm pumps.
I bolted my oem 155 right into my superjet and gained plenty of performance with 6 vanes and my tbm.
I am pretty sure too. Lol. There are many different 155 pumps though and I only know about this one from a jetboat.
