madness maker
John
- freaked on long island
Has anyone have any experience with adding spacers behind the impeller on a yami 144 pump? in our glass freak i am running a 10/16 hooker with a ported 61x 62t with the basics (head,msd cdi,lightend flywheel,reeds,b mod pipe,stock 38's, scat mag pump ,stubby cone and 85mm nozzle) ski runs good, but feels like its a bit over propped on the bottom end, not looking to buy another impeller or repitch,as prob going to a bb over the winter. i thought i read somewhere about spacing the impeller away from the stator to "loosen" the pump up slightly.. im hoping doing so may get it up on the pipe faster on the low end, i have seen 1mm spacers avail. but wasnt sure where to start, 1mm 2, or 3mm etc? or how much of an effect per mm of spacing. (currently the prop hub is real tight up against the pump center bearing hsg) thanks for any info.
