Yesterday evening this A/M REV hull was brought over to my house by a very good friend of mine. price was right so i took it. So with the square nose put on hold and hanging from ceiling above the REV, I am going to remove a lot of the carbon reinforcement and glass over to paint Then i am going to go to the underside and patch a crack it has in the bottom of hull and anything else under there. The tray is getting cut out only after i find out what was used in there if it was 2 part foam then its waterlogged then i will cut and remove the foam and replace with closed cell foam. and then the heavy hoodliner is pretty heavy so i will probably make a new one as well then paint it and turf it. It will have a 61x/61x 735cc 83mm bore and ported, Big 44mm sbn, B-pipe, Dual cooling, procool head MSD cdi enhancer adjustable hooker prop 9/15. I will still be needing a roundnose pole and a mid shaft from a roundnose as far as for a handpole anything that will work would be great and a gas tank would be freakin sweet probably just a stock one from a SJ would be fine. Here are some pictures but i will get some current in the works pictures tomorrow. It should be a fun hull for next summer maybe middle of winter.
