How long is your pole?
I wrote that and knew it sounded bad... but it is what it is. I got a new ski and it suspose to have a shortned pole on it... but I don't if it is or not. It seems really long to me. I don't know how short my pole is because it was broken a few time so I just shortened it as needed...
I need to know what is the standard length for a round nose pole?
AND what length is everybody runnning. Pole and trunplate.
Frosty
New York Crew
Western New York
Not entirely sure on the length of an OEM SJ pole... I am running an AC pole. I cut it -3", std UMI turn plate, 0 degree bars, lowered bracket. I think that all comes to what, maybe -4" to -5"... something like that.
Yea, Im doing all the work myself...other then laying up the Kevlar.....Hopefully the kevlar will be layed up this weekend. I am doing the entire boat. I am not putting foam back in this boat......I am going a different route....should still float if it does happen to sink....savn a little more weight this way.....saki you will get a kick out of this one!
We gota quit thread jacking. lol Im glad we at least gave speedfreak good advice on his pole.
remember the foam also helps w/structural integrity bronson.
blowsion doesn't make that deflector for that rear corner for nothing.
ive cracked a SJ hull back down there too from 3/4 BR's in the surf.
youre making a mistake. :27: :frown:
I thought I mentioned I was using kevlar on the intire ski:biggrin: Dot worry it will be alright guys.:bigeyes:
oxnard111
Creative RE Purchasing
I just bought a ski a couple weeks ago that has a shortened pole. I have never ridden with a shortend pole before. I am putting in foot wells into this ski, so once that is all done, I'm gonna have a drastically different ski.
Present Ski -
-Stock engine w/ stock pipe
-No footwells
-Standard pole
New Ski:
-Stock cylinder, Riva griddle head 35cc domes (175lbs of compression), factory B mod pipe, and dual 44's
-Wammer Rickters
-3 inch shortened pole
Pole is shortened three inches, that makes the stock graphic on the pole come right up to the handle pole bracket
Can someone measure a stock pole... I have 3 here and none are the same length.
Also does anyone run the XFT pole on a stock hull? Or is the Xmetal the way to go?
