- USA
Just to clarify, I researched all the fpp intsructions and the pictures of R&d routing, those are the first ones that come up when you google it. None of them make much sense, that's why I drew my layout so you guys can look at it and make suggestions. Just look at the pic I drew and tell me if it's right or adjust it. Kinda like Quickmick did in his reply. Thanks...fpp has type 9 install directions @ factorypipe.com
Details please. Which filter, where do you put it on the line....Run filters on dry chambers.
Ok, post a link of the seastrainer where I can purchase it...please.IMO..if you even think that you might be riding anywhere ever where you will possibly run more than 2 specs of sand through your pump I would run a small sea strainer with that pipe. Just add extra cooling line as needed so that you can place the sea strainer in a spot that it will be easy to see and easy to clean.
They clog super easy and ruin your day. With a sea strainer you can pull your hood....empty the little strainer cup...and be back to riding. Without one you are heading home to back flush the pipe with your garden hose after being towed in by your buddies.
Or worse if you don't catch it (watching pizzers) then you are melting things.
