- Clearwater, FL
A buddy of mine let me try out a skat superslim in my sj and after putting the prop in and starting the boat out of water I hear a rubbing sound coming from the pump area. That obviously means that the prop is rubbing on the wear ring. It doesn't do this with the stock prop, but I'm guessing thats because the stock prop is worn down to the size of the wear ring.
I've got a brand new skat swirl on the way and I'm trying to decide whether or not I should replace the wear ring or not.
It's an 03 sj and it was a saltwater boat, but the ski is mint and has hardly been ridden in the salt. There is absolutely no corrosion anywhere else in the pump area and everything looks great.
Would it hurt the new prop to put it in the existing wear ring and see if it rubs?
If I do need to replace the wear ring it seems like I have 3 options:
1. I can replace it with an new/used OEM wear ring. ($129 new)
2. I can replace it with an interchangeable plastic wear ring. (About the same price)
3. I can replace it with an expensive stainless steel wear ring. (Who makes these? I heard Riva does, but they only sell a 155mm wear ring)
Any advice would be greatly appreciated. Thanks:biggthumpup:
