SXR Sxr won't turn over NEED HELP!!
So basically, you had dirty connections???
It could have been a combination of dirty connections and weak battery. The first thing i did was clean them but maybe not good enough. Underneath the shrink wrap was rusted especially down at the starter. Also i assumed the battery was good since i jump started it got the same "click" and it's only 3 months old. BUT after getting a meter the battery was sitting at 10.something volts and it's not like it was hard starting up until then. I ride a couple times a week!! Should be charged right?? Do you think that would cause intermittent starting??? Anyways this has definitely has been a learning experience!! If this ever happens again i'll be ready thanks everybody for the input!!!
