Custom/Hybrid RRP fat bar steering
Cool, not sure why but JetManiacs the man so I trust his opinion. What bars did you end up going with. I know you were in the air with deciding whether or not to go with riser bars.
JetManiac
Stoked
orlando
I was going to but jetmaniac told me that this would be a better set up
They are both great steering systems and I told him as much when we were discussing steerings. I prefer a bearing system over a bushing system personally, but it isnt for everyone the CF is less expensive and low/no maintenance.
He has xmetal pole which requires some work with custom bushing setup to get CF to work. Newer adj xmetal poles are now predrilled for umi, rrp, etc. setups.
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
Chris, anything else need to be done to the XScream pole when running RRP steering?
Yeah, center hole has to be drilled out, I had to drill the 4 holes, you have to grind the steering stop a little.
On the bottom of the pole you might have to grind the hexagon holder so that the nuts fit but I just got longer bolts and used washers
