schicks
Karma Enforcer
- West Michigan
I ran into some spacing issues with the prop and the solas mag pump. I have a solas concord prop that does not fit up to the solas pump. When I went to tighten down the prop, it pinched between the prop and pump. The hub diameter is larger on the solas pump versus the oem pump, also the pump hub has a slightly longer length then the oem. The prop slid over the oem pump hub for the correct clearance, on the solas pump the prop hub is the same diameter and the pump hub which is causing the interference. So, I think I have 3 options:
1) add spacers between the pump and prop (this would work, but ideally you want the pump as close to stator veins as possible)
2) machine down the solas pump hub so that the prop slides over it like oem (keeps prop close to the stator veins)
3) not sure if there is a prop that designed to work with this pump?
What do you guys think?
