Custom/Hybrid BOB backfire
customride0105
sterling va
I'm noticed the marks on the nose of the crank. Check the flywheel for a crack and keyway is good on the flywheel.
What carbs? Am ? If so did u remember to put a jet back in the return fuel line?
Proformance1
Liquid Insanity
New York Crew
FYI, not that it should matter for you but the MSD instructions are incorrect on the battery and starter lines. They are swapped on the sketch. Im still sticking with my orig statement of places to look but next would be a stock known working CDI from a running ski.
masshole
i havnt pulled the carbs since i bought the ski when i did the swap i left them on. all i did was replace the fuel line. they are mikuni 44s
customride0105
sterling va
Are they novis full spec modded carbs most drill out the restrictor. So fuel has no back pressure and will cause backfires. And u said u replaced the fuel line my bet was there was a jet in the line and u didnt notice it.
masshole
replaced the lines after it was back firing as an attempt to fix it
Proformance1
Liquid Insanity
New York Crew
Are you just trailer running or water testing and saying that its still backfiring? Residual fuel in the exh will cause this, you must get the pipe hot and burn it out.
KTM434
Jamie FN Hickey
Palm Coast FL
Maybe I'm wrong but I thought it was backfiring and wouldn't even start. That would make it hard to burn the fuel out of the pipe
How is low fuel pressure going to cause backfires?
masshole
you are right it cranks, i get spark , i pull fuel but never turns over and when i let off the start button it backfires
Blue
Judging your cheapness
St Cloud Florida
I had a msd enhanser go bad in berkys freak it did the same thing. swap it out i bet its bad. Try a stock cdi just to test.
