- Trumbull CT
Whats the date on that MSD?
FYI the new enhancer comes with installation instructions and wiring diagram too
thanks it would be nice if this fixed it if not looks like ill have a msd for sale.
i havnt pulled the carbs since i bought the ski when i did the swap i left them on. all i did was replace the fuel line. they are mikuni 44sI'm noticed the marks on the nose of the crank. Check the flywheel for a crack and keyway is good on the flywheel.
What carbs? Am ? If so did u remember to put a jet back in the return fuel line?
Are they novis full spec modded carbs most drill out the restrictor. So fuel has no back pressure and will cause backfires. And u said u replaced the fuel line my bet was there was a jet in the line and u didnt notice it.
Maybe I'm wrong but I thought it was backfiring and wouldn't even start. That would make it hard to burn the fuel out of the pipe
you are right it cranks, i get spark , i pull fuel but never turns over and when i let off the start button it backfires
ok so before i order a new msd how do i check the woodruff key? it is a violent backfire and its as soon as i left off the start button. Another question can you have a bad msd enhancer and still be getting spark?
Turning over = engine cranks.
You mean it doesn't fire up?
