- Peoria, AZ
After many months of building my Superjet it is finally getting close to hitting the water. I started with my 97 hull. From there I stripped the hull down and took out all the water logged foam.  I shortened the hull 4” by cutting a section out of the back of the hull and moving the back section forward to retain the existing ride plate inserts. By cutting out 4” I was able to still use any ride plate that will work on a SN. I added a layer of 1708 biax for reinforcement to the complete hull and glassed back in the rear pieces of the hull.
