Solas 144mm MAG pump for Yamaha
These are the all stainless steel 12 Vane lower cost 'MAG' pumps that many have been talking about, JM earlier review here:
http://www.x-h2o.com/index.php?threads/solas-ss-mag-nonsetback-144mm-pump-review.103667/
These pumps directly replace your stock pump vane section. They are non-setback so they use your same stock driveshaft and will fit directly into your superjet -SN or RN including '08-'12, or Waveblaster.
You use the same wear ring and reduction nozzle from your oem pump.
These are big hub pumps so you want a big hub impeller made by Skat-Trak, Impros hooker, or Solas.
- Solas 144mm 12Vane nonsetback SS MAG pump for Yamaha $539. Sale 399.
Medium pump cone and SS allen hardware included
- OEM bearing and seal kit $119.90 sale 98.80
- Freestyle short pump cone for the Solas pump 58.90
Pump builds
JetManiac is also offering Solas pump builds with bearings, seals, driveshaft greased and installed -ready to install
Solas 144mm 12Vane nonsetback SS MAG pump for Yamaha 469.
Oring for reduction nozzle impeller washer/spacer included
OEM pump bearing and seal kit $99.90 sale 81.90
Driveshaft for SJ, '08-'12 SJ, or WB1 with clean oem splines 189.
Installation/pump build
Total Solas MAG pump
+add Impros hooker impeller installed option available
Solas 148mm MAG pumps
Solas 148mm 12vane SS Pump stator $650. Sale $549.
(Includes solas pump cone and ss hardware)
Solas 148mm SS wear ring $400. Sale $359.
Pump builds
