- North Carolina
was messing around with the superjet today and noticed when the bars are straight to jet is still noticeably angled....is that normal or do i need to adjust it some?
Make certain that whilst adjusting the steering it bottoms out on the steering stop not the cable.
sent from Fro Diesel using tapatalk.
Got the bilge pump/switch wired, Stock Flame Arrestor, and New Steering cable put on.....The steering now hits the steering stop on each side, however when the Steering is straight the jet is still just a hair off(like if you wernt looking for it you wouldnt really notice it)...Both of the connectors(bars and Jet) are turned about as far as i can get them...What could be causing it to be slightly off?
If it is slightly off, just disconnect the cable from the nozzle or turnplate, spin the collar a turn or two one way or the other and reconnect.
Move that ball on the turnplate to the outermost hole for quicker steering too.
The 90-95 and 96-07 cables are interchangeable and will fit on all years 90-07.
