Super Jet bore out nozzle/new look
Spokane,wa
blue print pump
ok did some searching again and found alot good than bad so i went and broke out the demel tool which i think it really suck for grinding down the imperfection on the pump so i went a air tool and a cutting bit...beware if your going to use the bit it cut fast...all in all it turn out pretty good....now all i need to do is use the demel to smooth it out then maybe polish the pump....
pump
here the tool
now i can wait for winter to be over:rant:
BruceSki
Formerly Motoman25
Long Island
I used the same exact bit to do mine. It gets galled up with aluminum quickly though. Had to scrape pieces of aluminum out of it every few minutes so it would cut again.
Spokane,wa
yeah i was looking for one of those, didnt have one or the money to buy it. So i just used the ole dremmel, with sanding drums took forever but i got it.
i try the demel and it took to long,then i remember i have the cutting bit.i still used the demel to smooth the cuts.....
here how it turn out i didn't really smooth it out cause from what i read it will work better then having smooth surface so it kind of smooth...don't ask why but i just went with what i read....
I still need my nozzle, just don't need the cone that attaches to the stator. Are you talking about the Stator? The part with the 6 veins?
#ZERO
Beach Bum
Florida - U.S.A.
So you spent around $24.99 for the sanding drum set plus $7.99 for each grit sand paper sleeve set with a grand total of around fifty bucks in parts plus your time, tools and labor?
Spokane,wa
the only stuff i paid for is the drums to bore my nozzle everything else i had laying around in my tool box from my last sport bike build...the season for riding is over so i just decide to learn some stuff and to know what my ski have...better time than winter time....
Spokane,wa
i just upgrade my backup sj head.thanks again to Chris @ jetmaniac for making happen....
from this
to this
Spokane,wa
no i haven't rode it yet,but my main ski had the same set up,being worth it i say yes,it dose give u alot of low end brappppp
