There are stringers and three sealed air chambers. If your hood pops off in the surf, the ski will float as good, if not better, as any other foamed ski.
They said that if the Titanic's hood pops off, it'll still float?
There is no foam in the Freaks.
pieces of Alum that run parallel to the drive shaft tube , they add support to the tray and seperate under the tray area into three seperate compartments
Chad, pc of alu running parralel with the drive shaft tube (along the ski) or across in the freaks? Wonders why it isnt carbon?
Nice work keep the pics coming.
BTW are they about ready start neutralizing those weapons yet
Sent from my DROID X2 using Tapatalk
What kind of a riding season do you guys get there.
It should be happening pretty soon. Too bad it will only last a few years as far as operations goes.
Did you decide on a motor?
