Super Jet new ada/impeller
Spokane,wa
i installed my new head from jet maniac w/35cc domes....now i looking for a impeller,i'm thinking i want more low end but i don't want to take to much of the top and mid..so i search and look and was thinking maybe a 9/17 pitch...so what do u guys and gal think.....
this is what i have on the motor
ada head w/35cc domes
pro tech exhaust
vortex f/a
pump cone
stock impeller
as far as pistons they are not bore out and no porting done to the motor...
anyway here some picture
this my kid messing around with my back up ski....lol
Spokane,wa
by the way i ride mostly flat water and i don't race,would like to get out of hole faster and i like the top end to get to a spot faster..i will try the ocean next season so the impeller has to be good for the ocean too.so basically it has to be a all around impeller,but still have a good amount of low end
Oh crap, just realized your in WA. I saw your post over on PWC today and commented on it. A hooker would be impeller for you. If you want something that going to give you lots of bottom end but also give you flexibility for the top end a 10/16 would be a great bet.
I went with the 9/15, got a tremendous amount of lower end (came with mods and impeller upgrade at once) and also gained a few 2-3 mph on the top end as well.
Im in Currently in Moscow, but we ride with guys in CDA, Spokane, Liberty Lake, Spokane Valley ect.
Shoot me a PM if your looking for some riding friends! The more the merry!
Lots of information can be found about the hookers and which is right for your set up here. http://www.x-h2o.com/threads/37009-New-Impros-Hooker-Impeller-for-Yamaha
Spokane,wa
Get a hooker 10/16
thanks guys for the info.i pm chris at jetmaniac and suggested the 10/16 pitch too so i went purchased the hooker prop from chris.if anybody needs parts i would buy from chris at jetmaniac
my hooker is order and sitting on my lap.....lol......
Spokane,wa
I dont think you'll have the power for a 10/16, I would run the 9/15
well it's to late now....i have already purchase the impeller and with the info i was given and found,it look like the 10/16 will be the one for my ski...and if not i'll get the 9/15 later,but i will not know till next season:grumble:.....here some picture
dame didn't even know how much dings my stock impeller had till i pull it off:bigeyes:but it still run pretty good:dunno:
here my new hooker 10/16 impeller installed
motoman96
Banned
Lodi Cali
I ran a 10/16 in my fx1 with a superjet pump. All I had was a high comp head, a/m carbs, reeds, b-pipe, tdr waterbox, stubby pump cone an a OP steering nozzle. It friggin ripped
The 9/15 was perfect for my SN when I was running a ported 701 with a b-pipe/head. The 10/16 worked alot better with my buddy's 771. The 10/16 will work fine, but there will be more hesitation right off the throttle
yeah i was thinking of having them do the work too.but can they re pitch too?
of course they can . By the way your stock prop looks like an 08 SJ prop i run one in the SJ and prefered it over the 9/15 hooker for all around riding.
Usually lighter hull can turn steeper prop (on the fx1 i run a c75 13/18skat on my 650pump with a 780 motor)
Spokane,wa
If your going to stick with the 10/16 bore your nozzle out
the more i look at my nozzle on my main ski,it look like the last owner had it bore out already,just comparing it with my back up ski.....
here some picture maybe u guy can make head or tail off of it...
this is my backup ski nozzle.the wall look thicker
this is my main ski nozzle,the wall on it look thinner
Spokane,wa
i like my stock prop it had a good amount of low end and it is good for all around riding,but i couldn't handle how much cavitation it had....idk maybe it was the damage on my stock prop that cause so much cavitation..anyway i was planning on replacing my impeller since i decided to trick out my superjet
Spokane,wa
measure it, your going to want to be around 84.5mm to 85mm
ok,i going to have to buy a measuring tool to measure the nozzle it should be inexpensive tool....harbor freight is my friend....:naughty:,by the way from what i was told from the last owner it may have been bore out cause he had blowsion do all the mod it idk.i will not know till i get the tool....:shrug:
