- Boynton Beach
Any suggestions what I need to change to make it work? It turns to the ride fine, but left turn is not better than with the stock steering system which is horrible. I am able to put the steering cable only on the inner hole, it does not fit on the other two. The brass nut that holds the chinpad is on the way also. I cut the chinpad as much as I could, but still no luck.. I trimmed the nozzle also, but no luck either
Should I get pre-08 cable, nozzle or do something else to make ti work? The stock 2010 nozzle has this trim adjustment that the pre-08 dont have which might be an issue I guess.
Any help or suggestion is appreciated. I can take photos for better view...
D.
D.
