small gas tanks
^^^^^Never thought of that. I only have single cooling right now, but my ski is not ported or anything. The motor has not failed me yet, after pobably 30-40hrs since I have owned it. The tank was already burned when I bought the Ski. You dont think under normal circumstances that a B-pipe rubbing constantly on a plastic fuel tank would start to burn/melt the tank? I have since put a peace of rubber to space the pipe from the tank.
Jawbreaker
Rick James Edition
Music City, TN
If you run an internal filler and a MOD chamber, the stock tank is effortless to remove. I can pull out my tank with 4.8 gallons in it in about 15 seconds. AND you don't have to remove the battery tray.
If someone made a black plastic OEM tank, I'd be all over that.
I have to unbolt my motor mounts to get my gas tank out of my Octane.:banghead:
Rickster
Matakana Menace
:dunno:
I can put my bare hand on my pipe, so I would not think that it could burn through a gas tank.
As long as she is running alright, who cares...:biggthumpup:
i think he meant friction burn.... and yes, it can happen. applying a piece of turf to the tank in that area is a good way to prevent it from happening.
