My whole ski went under and I finally drug it to shore. I got the water out of the hull. I pulled the plugs and i see water in there as well as the carb air filters off and when I open the throttle i see water or what appears to be water in there. What are the next steps before I try to start it again. i don't want to screw it up. Should i tip it over and get the water out of the plug holes. Do I need to pull anything else off? Is the stator cover the big plate on the front of the engine? Does that need pulled? The ebox?
