Installed a new TBM flywheel with no problems whatsoever. It didnt bind and dropped into the case without a hitch. Went to go ride it and the ski was hesitant, but after pumping the throttle 2 - 3 times it would take off and top out as well, so i figured it was a timing issue; rode this way a couple hours. Ended up taking the ski home and installing a new billet flywheel cover and noticed some shavings in the case, pulled the flywheel and come to find out the flywheel hub was rubbing against the stator plate! Luckily i didnt blow any coils on the stator or even worse f- up the engine!
The TBM hub is alot thicker than the stocker hub, but whats weird is that it didnt bind at all during installation.. Now how did that happen..
