Aircraftsalz
Thrust built Dasa Power
- Off site
Just picked up my new Full Glass wet layup Surf Badass.... Tem did a great job making a glass hull.... I love my light FW freak, but to me a 80-90lb freak for the surf is going to be unreal. I'm not a big fan of 50lb hulls in the surf, I think a little weight really helps. This is the perfect surf ski imo..
Big Thanks to Tem @ Superfreak for building great hulls to customer spec, Also
Big Thanks to Brian at Thrust for all his help with the motor, trim, you name it he's got it... Chris Jetmaniac for all those little build parts!
And man if Lucas didn't push me to buy another ski, my wifes going to kill him!
Details:
-1.5 Glass wet layup hull, center re enforced with Carbon 83.4 lbs with footholds, pump shoe, inserts, Carbon exhaust tube.
Hood Bomb proof Carbon, vacuum bag, etc 8.6 lbs
Build will have the following installed
Superfreak full length Carbon pole (6-7lbs)
RRP Steering system
Thrust Straight pull Trim
144 Mag or Thrust pump, 14/19 prop
Pro Tec Nozzle by Thrust
Motor:
Thrust built Dasa 846cc SS setup for Avgas, Full Spec 46's & intake, B pipe, XM waterbox, ATP Epic, TBM FW.....
Thats the basic setup, should make a great surf ski, still pretty light, good power....
Details:
RRP Steering system
Motor:
