Super Jet superjet rn midshaft bearing sealed?
Some don't know that those bearing seals pop off the actual bearing itself to allow re-pack the internal bearing for re-use...they are semi-sealed to hold grease in but the housing grease is the real seal against water...
also as another option, the blaster bearing is beefier/wider and used in the same housing but cost more...
match up the bearing with oem type with the black seal on the side that will pop off and can be re-packed with grease....you still have three seals in the housing surrounding the bearing, one in front and two in the rear.
chriselmore_1
high on resin
san jose ca
are the seals made by yamaha or koyo? I have an fx1 housing that has koyo on the spline side seal. Tryin to figure if the bearing shop would have the seals
chriselmore_1
high on resin
san jose ca
not a shortcut dummy. Same exact stuff that you would get from yamaha but I can get it local and not wait a week and it's less than half the price.... Do some research...
