wydopen
onthepipe
- Goleta the Goodland
i dont know if other people have been doing this and i dont know why i didnt think of this before but if u prefer to run no lanyard and dont like having a zip tie holding up the little post this might work for you..
if you take apart the start stop switch unscrew the little nut that holds the protective rubber boot that goes over the "button" that sits under the lanyard peg..
underneath is a little white plastic post...when the lanyard is removed it pushes down on the white post and cuts the motor..
just cut that little post off flush with a pair of dikes and put the rubber boot and nut back on...now u dont have to run a zip tie to hold up the lanyard peg anymore..
like i said maybe everyone else has been doing this but generally i see people with a zip tie in place of a lanyard..
i dont like running gloves and i always cut my hand on the start stop even with a grip donut...
so last night i was bored and took an old wetsuit and basically turfed the entire start/stop assembly...its pretty nice and cushy now and i dont have to worry about it cutting my hand anymore..it didnt come out super clean but with a little more time anda heatgun you could probably do it with minimal seams...the razor i had was kinda dull so it looks like a rat gnawed out the holes for the red and green button or else i would have taken a picture of it...if u dont like wearing gloves and you are sick of having a hole in the base of your thumb all the time it might be worth doing..
