mademan9
I ride a SuperFrk WannaBe
- Lafayette, Louisiana
So here is my problem. I have a 61x/61x motor that will not start with the s/s switch. I tried to rule out a bunch of things and still nothing. I went through the wires on the switch to see if there are any frays. Nothing. Then I checked the connections in the ebox. Everything seems to be tight . It does crank with a screw driver on the solenoid. I actually changed the solenoid to make sure it wasent that. The battery is charged. What other test can I do to find the problem?
