Surfriding Jet Works FCV pro..... What is it set at right outta the box?
Just got a jetworks fcv pro in the mail and was wondering what it is set at right outta the box. The standard fcv is set at 3.5 psi but what is the adjustable set at before any adjustments made.....? Any info on this product would be awesome.
Thanks
Chris
:beerchug:
chriselmore_1
high on resin
san jose ca
chris run your bpipe like we do. I tried a fcv then went back to the setting from larry and jared. No water in the stinger. Top and middle screw closed and bottom open .5 turns. That setting let me run a bigger low jet too.
Idaho
I usually pull the line off the stinger with the ski on the stand in the water. Watch your tach and note the RPM when the valve starts flowing water. I have found that many times the valve never closes all the way when going back to idle. If you shut the ski off, the valve will fully shut and will stay shut until you restart and go up to say 3500 RPM or wherever you have it set at.
