What are you guys doing to keep your XMetal pole bolt nuts from backing out? I'm running the first gen xmetal pole. I've tried extra washers and lock washers. I have a tad of anti-seize on the threads and torque the hell out of it so it's nice and snug, but eventually...maybe two or three rides later the back out and the pole is sloppy loose. McDog told me they (Xmetal) recommend red Loctite. Maybe I should ditch the anti-seize on the threads. You guys heard anything different or have a solution. I miss the single pole bolt and spring setup.
