Super Jet Magnum size for Freestyle Brapp
Proformance1
Liquid Insanity
New York Crew
Call some of the dealers they will point you in the right direction. They do this more thatn the rest of us and can answer all your questions. X scream, Impros, Thrust Innovations, Blowsion, Skat trak, LPW, Jetworks, Jet Maniac, etc Seems to me smaller motor smaller pump but to go from 800 to 1000cc with the same pump, I would feel you are giving up something on both ends.
EME uses a 145 ... and I think the argument could be made that they make the most power available in the industry with the polaris based 777 case . There are many ways to skin this cat with props , nozzles , intakes ......
Fl
For sure Sportfish, I wonder if you had a 148 and a smaller motor and you put a big cone and smaller reduction nozzle with a cut back prop if it would give the bottom end we want. So many fun experiments to do.
this is close to what I have,except Im using a larger reduction nozzle to hit hard off bottom. It really rips,so I think its all in how you prop it and bore the nozzle,that said im selling or trading the mag 148 13/18 setup I have now to try something for a totally diff purpose.
