- Hutchinson, Kansas
I have some novi carbs for a 800 yammie engine
if anyone wants them then $650 takes them away
Hey wax, do think you could convert one of your ignitions to work with the 66e motor. I think the stator is the same as the 760's, I know the flywheel is the same and the taper on the front of the crank will fit the 701's flywheel also, however the stator is on the front cover. Any ideas?. I'd love to run your system instead of tl.
