finz08
fx--1
- Bakersfield CA
Do i need one for the surf?
Not really - It's actually a hinderance to most... Those precious seconds that it takes to plug it in can make the difference of you getting swallowed and wadded up.
I prefer to set my idle low enough so it chugs for a few seconds and dies.
youll be sorry when your throttle springs breaks, and have no lanyard. its happened to me (with lanyard), your ski will be off to asia.
That is what the little red button is for...
Zip tie in the surf for me!
nothin like scramblein to get your lanyard plugged in while an 8foot face is climbing on you, gettin it plugged in too late, get smashed and held under, swamp your boat and get washed up into the rocks and crack your hull, and have a wave slam your hull into your knee against a rock...
I don't zip tie, but I do have a lanyard key zip tied to my bars. That way I can plug it in, but also easily unplug it and put my real lanyard in.
Red button not much use if you are seperated from the ski.
Red button (on SJ's) is set up in such a way that if the button fails (corrosion in button, corrosion or loose at the black/white connectors) it will not shut off the motor. Granted in this situation, if I recall correctly pulling the lanyard won't kill it either....
Wayne (rides a 800SXR) who rides o-side sometimes was running camera on a scaffold at that event and was knocked off by that run away blaster.X2- Personally I hate them. I zip tie mine up. But technically I think its the law? The lanyard law stemed from a collision at some races held in Mission Bay about 15 yrs ago. On the race course a ski collided with another puncturing the fiberglass on the side which lodged into the throttle on the carb holding it wide open. The rider was thrown from the ski which was headed for, and ended up in the crowd up on the beach. I can't remember if any one was injured. If he had been wearing a lanyard the whole thing would have been prevented so the lanyard law was the result.
