Zeeltronic wiring on Kawasaki
Looking at trying a zeeltronic on a 750 big pin in my x2.
Only thing I'm not sure about is the polarity of the position sensor. I have a scope I can even figure out which wire gets the positive pulse first...but the zeeltronic documentation doesn't tell you which wire on the cdi that should go to.
So rather than guess and check, figured I'd see if anybody knows.
Also interested in any curves that people might suggest, and static angle.
waxhead
wannabe backflipper
gold coast
here is the easy way. you hook it up and see where its firing. If you have it back to front it will pick up from the wrong end of the lump and you will be about 25 degrees out. so you will have a silly static angle of about 25 or s degrees and you will not be sure why
