I see a lot of the pros running the Rick roy Products (RRP) pole, but I have felt that and noticed that it is quite heavy. When you are making tons of hp, you can sacrifice a little weight. I personally think the XMetal is a very clean and sexy pole, but if you are really out for the lightest, I think the XFT has that (it is also a nice looking pole). However, for the money and all around looks, the XMetal takes the prize.
Edit: I do recall Pat (XMetal, IKSTEJ on here) mentioning that the latest poles are going to be lighter than the past XMetal ones. I had a discussion with him once regarding the fact that the weight in the XMetal pole is uniformly distributed throughout the length due to the heavy gauge extruded aluminum tubing (well, not really heavy, but since it is the largest single surface of the pole it becomes heavy). He mentioned that he was planning to use a thinner gauge aluminum (or extrude it to a lesser thickness) to bring the weight down. He was targeting 8-9 pounds. Check with him on that, or Pat chime in with an update (am I putting you on the spot?):smashfreakB:.
