OCD Solutions
- Rentz, GA
You are speaking of the starter teeth, brushes are internal to the starter motor and would require opening the starter to inspect. Not really a serviceable item unless you really know what you are doing.
Can you post a pic of the nick you describe in the starter teeth? If its minimal and any missing pieces are accounted for, you should be able to reinstall it and at least test it to see if that's the problem before you go ordering parts.
