Hi Chuck, Welcome to the X.
I agree with Chuck, Run the ADA head & girdle kit with your build. It will save you on many fronts. I also agree that most rec freeride boats don't need that high of compression
There is a big differance in cyl setup between Yam style domed pistons & kaw style flat tops. The dome style is just a part of it.
the big differance is piston dimensions. The "timing edge" diminsion is 4mm differant. (distance from the top of pin to the top dome edge) the FT is shorter. so the cyl need to be machined accordingly. The skirt will also need to be modified to be used on a std stroke or the skirt will hit the cases.
Many engine builders have differant feelings on the FT/ domed debate.
I personaly like the added power of the FT. But to many the cost of building it is not worth the gain.
as for the carbs, Definately duel 44's, or if your budget permits, 48 Full Specs
Chuck, Please feel free for your comments, as you have already, Your contributions here just took the tech level of the site up a notch. welcome!!
ski ya, Paul
