Yamaha 4.5MM ADA stroker crank, 6MM Rad stroker crank, cases
OEM 701 crank stroked 4.5mm by ADA back in the mid 90's when that was a regular thing, Had it in a 5mm ABLE cylinder stroker motor RN SJ when I was still racing. Had it rebuilt once by ADA around 98 (as I recall), and it probably only has 6-7 tanks of fuel through it since, been sitting on a shelf in my heated shop. Will come with some lightly ported cases that were originally done by Gary Lamb back in the same time period, I replaced the case seals with OEM a couple years ago cause I was gonna run it, and painted the cases as well with real automotive paint. Bedplates are freshly powdercoated as well. Ended up selling the cylinder to a guy on here that needed it, so it's never been used since seal replacement. Bearings are smooth, Rods are tight, crank and cases are ready to go. Stock length rods. Crank, cases and bedplates for $400 shipped, or will sell crank only for $295.00 shipped. Domestic shipping only. Red anodized driveshaft coupler and flywheel bolt are gone, not included.
Also have a VERY lightly used RAD billet 6MM crank, only has one season on it, came out of a B1. Same deal, been sitting in my shop unused for a while. $600 shipped for the RAD crank. Will get some pics later and update thread.
