yamabro
GP Performance / Patterson Powersports
- Dickson, Tn.
I’ve been toying around with this cause I had the parts just laying around.
OEM Yamaha 155 pump stator housing (chipped stator veins)
Cut out center hub and bored housing
Then machined center hub
OEM Seadoo “Plastic“ 10 vein Mag pump 155, stator veins are chipped BUT I didn’t want to sacrifice a good one until I knew this would work.
Machined outside of plastic pump to press fit into yamaha housing
Machined Seadoo hub to press fit Yamaha hub so I can run Yamaha drive shaft
Feels light as a FEATHER!!!
The finished product will have perfect stator veins.
Also have this Aluminum 10 vein MAG I’m about to machine to build an all aluminum pump.
