KDX 1200 "The Grape Ape"
Placed 6th in Pro Freestyle at 2012 IJSBA World Finals. Very Custom/Competition spec built (secret sauce)
Ski has standard wear on paint and turf but overall stunning ,
pristine condition, and power like new.
It has been in storage for many years with only a handful of rides (only freshwater). Ready to tear your arms off and you'll be smiling the whole time!
Features:
XScream Kong Dominator (KDX) Hull - Ultra-strong carbon fiber construction - 50 lbs.
XS1200 Short Block (1200cc)
Full Spectrum 49mm Carburetors
Custom XScream Intake with Reeds
Modified Power Factor Dry Pipe
MSD Total Loss Ignition
XS Carbon Fiber Hood, Nose Piece and Footholds
XScream Adjustable Pole Kit with Chinpad
XScream Adjustable Steering
XScream Throttle Trigger
XScream Stainless Steel Trim System
XScream Hood receptacle, front hooks and latch
XScream Bypass fittings
XScream Scupper
OEM Starter and Bendix
OEM Start / Stop Switch
All OEM Hardware, Cables and Fasteners
2.5gal Fuel Tank
Custom Intake Grate
Custom Skat Trak Set Back Magnum Pump
High performance impeller manufactured to XScream specifications
Modified and Bored Reduction Nozzle
Modified Steering Nozzle
Custom black anodized cylinder head, bed plates, and flywheel cover
Pump gas domes
This engine uses an 84mm billet crankshaft designed, built and balanced specifically for the XS1200 (Stroke 84mm x Bore 94.5mm/95mm). The engine features modified Yamaha 66E cases with a custom stator plate allowing the use of a Yamaha 701 / 62T style MSD Total Loss ignition system. No exhaust adapter is required for 701/760 style exhaust systems.
XS1200 Short Block Features:
True 1200cc displacement
No exhaust adapter
XScream Freestyle Cylinder Porting
CNC Port matched 66E cases
62T style stator adapter for MSD Total Loss Ignition
XS Custom Flat Top 94.5mm / 95mm Wiseco Pistons
84mm Billet Crankshaft designed, built and balanced specifically for the XS1200
XScream Custom Sleeves (94.5 to 95mm)
Custom Black Bed Plates
Custom Black Billet Front Cover
Video of the ski in use: Click here to see it in action
More info: Click here for XS1200 Spec Sheet
Price: $17,500
Manufactured by X Scream
Features:
XScream Scupper
2.5gal Fuel Tank
Custom Intake Grate
Pump gas domes
No exhaust adapter
Price: $17,500
