Other Xmetal pole/pinch bolts removal help
Trying to remove an xmetal pole, pinch bolts are stuck in the bushings. I've been through this before but these are stuck chuck. Any tips for backing them out?
Sent from my DROID X2 using Tapatalk
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
I've taken an old ratchet and a small socket I don't care about - stick the socket against the bolt and hammer on the ratchet as close to the head as you can.... Make sense?
