- Mooresville,NC
I just bought a xmetal dual breather bracket and im using a umi pole and the stock handle pole bolt and i was wondering if there is a way to use a spring with it to?
thanks
Charlie
thanks
Charlie
you could try, but the pole really needs to be used with the XMetal bracket, the stops on the bracket are designed to be used with the pole, Superramjet tried the XMetal Pole on a WDK bracket, it kept breaking, the limiter on the bracket was different...........
run a single tube, bolt and spring, but use the XMetal Bracket with single hole in it.
no, there is not enough room for the bolt and spring........
