Two things with the ninjas I can point out when I played with a set.Jetting the Ninja SE 50's. Came with 110 MJ , 145 PJ, was given a suggestion of 122.5 MJ and 150 PJ, so I'll start there and have everything around that on hand. Oh yeah, 19 psi pop-off.
View attachment 454589View attachment 454590View attachment 454591View attachment 454592View attachment 454594View attachment 454595
The returns are not drilled, I drilled mine, seamed to solve some loading up issues.
Check the epoxy/sealant under the pump. I had the epoxy on mine come lose.
More drilling AND more epoxy !!! Just what I want to hear guys, lol ! Only kidding, taken under advisement, just want to ride it for now !Looks good! +1 on fixing the epoxy and drilling the returns. Use JB weld tank weld. I drilled the returns just so they’d stop getting clogged.
Mike, are you actually going to run that battery? Are you going charging system?
Big thanks!Absolutely mental build! Cool to see these still happening and being documented here.
Pretty sure that's Tygon. Not sure how it compares price wise but it's very good fuel line. Not the prettiest but very functional and good quality.50k jet ski. Cheapest fuel line you can get. Weird stuff. Sweet ski tho
Yeah the op mentioned it was tygon . We use Tygon for swimming pool applications . We supply straight acid through it with no issues. Over time anything cracks though. I’m pretty sure tygon specific to gas is not the cheap stuff. Tygon makes the non kink lines for oxygen supply for anyone on home oxygen tanks or supply as well.Pretty sure that's Tygon. Not sure how it compares price wise but it's very good fuel line. Not the prettiest but very functional and good quality.
