Xft trim cable
contact one of the cable manufacturers.they should be able to help out by reusing the xft ends.
i assume you have the one with the spring and rigid end (last version)
thru hull fitting you're going to use a oem sj threaded cap and somehow thread a plastic pipe to fit it.
or just run a regular trim cable made to custom length .
but nobody manufactures them anymore? have seen lots of trims and cables but i think xft has best one atleast the cable idea is good..
i dont have xft trim but my buddy has and now i want one.. i have thrust ez pull trim system and its good but xft looks super strong and there is more throw in it.
nope.cable was made in brasil.the extra throw comes from the system,not the cable and unlike the thurst,it is not an easy pull.
i do have a new complete xft system if you want.cable,thru hull and complete nozzle assembly.red/orange carbon kevlar.
