Used XFT FLY-X -SOLD
superjetguy
It's hard to speak without a tongue.
lake hogan
Motor:
718 ported 61x (jetmaniac)
Pro X pistons
Ported cases
Pro tec intake manifold
Boysen fiberglass reeds
Art Gomez (Jetworks) 38mm black jack carbs
ADA girdled head kit with 33cc domes
#Zero lightweight flywheel
JSS ignition coil
Factory B Pipe
Dual 1/2” cooling
All stainless hardware
Pump:
144mm Solas Mag Pump
New wear ring
Hooker 9/15 impeller
Custom nose cone
Bored exit nozzle 86.5mm
Thrust Trim system
Hull/Pole:
Hull is carbon Kevlar
XFT dual footholds
XFT ride plate
XFT pump cover
XFT hood latch
XFT hood hooks
Dual 1/2” cooling
XFT dual scupper valves
XFT carbon fiber pole
XFT chin pad
Aura OTP steering system
Carbon Fiber bars
Odi grips
XFT finger throttle
XFT side exit exhaust
XFT front exhaust (not currently used)
$6000
