madmike
X
- Vilano Beach
I bought this a few years ago thinking I would have the time to finish it and enjoy. I'm throwing in the towel...
I purchased everything needed to complete this project. The only thing it needs is an exhaust pipe.
The hull had a starboard hairline crack that was repaired by previous owner, and it was done right! see pics.
I don't have the time to part it out, so hopefully someone will take the whole lot.
Take it all for $5500
Here is the list for the hull:
XFT FLY-X back-flip hull, X-PRO VISUAL CARBON
57lbs when built.
Includes:
Double scuppers
Pump shoe
Dual cooling line pass thru
Trim cable pass thru
Two positions for motor & pump
XFT hood with double seals
XFT spare visual CF nose piece.
XFT visual CF handle pole & chin pad
XFT handle pole pivot
XFT hood hooks
XFT footholds
XFT steering system complete and one spare
XFT CF/Kevlar batt box
XFT gas tank
XFT 2 rideplates
XFT intake grate
XFT Visual cF Trim system.
XFT clear lexan coupler cover.
XFT fitting and throttle.
XFT hood latch.
Every XFT part I could get a hold of Goes with this sale!
The motor:
Freestyle ported motor. New crank. New pistons. New everything, etc.
Pump is a solas 6vein. Complete. To match motor.
New parts purchased Jetmaniac:
ADA billet head
ADA domes 35cc
ADA hardware head kit
(2) through-hull fittings kit (see pic)
(2) Rhaas 'no slop' SS cable ends
Larger 6mm Size for B2 cables
(1) MANIAC Big Bore Throttle Cable
(4) rhaas engine lock washers
RRP trim cable
RRP trim cable bracket
SS trim return spring
Thrust trim steering cable extension and heim joint
gaskets 1ea - flywheel cover, intake manifold, reed, dual carb 44
(1) oil block off plate
(1) JetManiac dual carb brace
(2) Slimline High flow fuel filter with 90 Micron white polyester
element
(1) Fuel tank check valve
6' Fuel line -translucent red
10' 3/8 water line -solid blue
(1) pump seal
(1) engine shim kit
(1) 3 finger midshaft coupler
(1) MSD Boots and Crimp-On Terminals kit (includes 2 of each) 13.
(1) MSD Mini Stripper/Crimper Tool 12.
(1) SuperJet waterbox straps
(Oem clean used, about 14 inches hook to hook unstretched)
(1) Shorter battery straps
(Oem clean used, about 12 inches hook to hook unstretched)
(1) Tank straps with attached mounting end on 1 and hook on other
(Oem yami clean used, approximately 17" unstretched)
Good for kart tanks and PFP style pipes.
(4) Motor mounts
All electrical parts with extra complete electrical box assembly with MSD Enhancer
I'm sure there a lot of small parts that are included that Im missing off this list.
Take a look at the pictures for a better idea.
If your interested please text me 904-712-9090
I'm located in St. Augustine, FL
I can palletize and help with logistics.
57lbs when built.
Includes:
Double scuppers
Pump shoe
XFT hood hooks
XFT footholds
XFT gas tank
XFT 2 rideplates
XFT intake grate
XFT hood latch.
The motor:
ADA billet head
ADA domes 35cc
RRP trim cable
element
(1) pump seal
(1) engine shim kit
(4) Motor mounts
