- Australia Melbourne
Play in the UMI steering, is this common?? i just bought a brand new UMI steering which uses the old steering throw arm from the origional setup, anyway there is about 1 mm play or so in the steering from the throw arm not seating 100% on the shaft...
Now i have 2 older UMI setups here both with alloy quick steer type extentions, and they both have the same play, so i tapped an m6 bolt in it to eliminate the play... But cannont do that with the new one... what have others done?
Have others just put-up with the play in the new UMI's??
