w-nut
x2 nut
- christchurch new zealand
i thought id might be a good idea to start a thread so we can all come in and tell wot engine set up and jetting we are useing , it would be handy to have a big list in one place so people could find and look it up easly
here is mine
95 small pin 750 fpp 650 pipe 160psi compression carbon reeds (unknow brand came with the carbs) duel 40mm kehin sxi carbs everything else stock
Main jet : 125
Pilot Jet : 75 (Stock)
High speed screw : 3/4 turn out from closed
Low speed screw : 1 turns out from closed
Needle & Seat : Stock
Spring : Stock
Comment: Stock spring
here is mine
Main jet : 125
Spring : Stock
