- Albuquerque
I understand what you mean. Yes, it's true that there are not many straight bar system with pads on them. I am 100% sure you can get a A/M steering system that will work for your UMI bars.
I have seen those steering system one time but I have not heard much about them. I keep hearing a lot of people recommending RRP, Cold Fusion, and xmetal all the time. I had to drill/tap the x-metal pole for my RRP steering plate and only took me 20 minutes. I can ask some people around for a steering system that will work for your UMI bars. Is your UMI bars a straight bar? You are a mechanical engineering? No kidding, I'm an mechanical engineering student.
The RRP system you have will mount my bars, just like the Kommander set-up. I think I had my terminology wrong. I have 0 degree bars. It would appear that straight bars are, well, a straight piece of tubing. Mine is like the stock bar arrangement with a crossbar/pad. Either set-up would work fine (heck, they look identical in the pics). No kidding, I have an MSME and appreciate good product design. How far through school are you? Any idea what kind of work you want when you're done?
I have never seen anyone using dual pivot bolt method. It could work well and won't be in the way for the cables to go through. I'm using the stock bolt and not using a spring on the x-metal pole. The stock spring has way too much tension and the x-metal pole stay straight up. I am actually looking for a lower tension spring just in case. I have old pain on my lower back, I fractured four of my vertebrae in a ATV accident five years ago.
I'm going to do the same, reuse the stock bolt and bracket. No sense in reinventing the wheel if the stock parts work fine. I hadn't come across any info about the stock spring being too tight yet though...hmmm. I guess I'll look into that when I get there.
Thanks for your input on my other thread (sanity check). After much thought, I think I'm going to just do both the FW and pipe at the same time. Those FW are super expensive (not sure why exactly, not much to them), but after searching for hours...a lightweight flywheel is mentioned a lot. It's just money right...haha!
